    Default Turbo fitment differences between 180SX and S14.
    So story is I have a 180sx straight cam engine and I am fitting a 2871R to it.
    I want to fit braided lines and also a stainless elbow and downpipe to it.
    My question is will the braided lines for a S14 fit? I think one of the water lines at least is different?
    Next question is much the same but for the elbow and downpipe, are S14 items the same or do I need 180SX specific items?
    http://r32life.blogspot.com/
    MEATH
    Billy if you block off the coolant hose at the back of the head (at bulkhead ) then get a outlet pipe (at cas) off a s14 you can run the s14 braided pipes handy then. Done it before on the same engine and it worked fine
    Elbow are the same i think , downpipes - i'd try use the rb one ? if this is for the 32
