Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 24
Thread: steering
  1. #11
    Dec 2009
    Who did your hubs...!
    Quote Originally Posted by DaveZigen View Post
    It takes no talent, sacrifice or commitment to be a critic. Fact!
  2. #12
    you will also need to check your caster settings as this will affect the bump stop position. ie the bottom arm position.
    do the steering arms hit the bottom arm at both sides when on full lock? if so you need to increase your caster until there is only a slight gap, say 5mm. now obvioulsy when you do this you need to make sure caster is the same at both sides and at a setting you require, for eg on my own car at that point my caster is just over 7.5degrees
    its hard to figure out whats going on but if the hubs were just cut and welded randomly then if they are just slightly different it can make a massive difference and i would guess that theres your problem
  3. #13
    di Member Driftma's Avatar
    Dungarvan,Co.Waterford
    Quote Originally Posted by ian g sr20 View Post
    The rack can't b off now as i done was Chris said I centered it when it was disconnected from the hubs. Looks to me as it the modaified hubs are diff lenghts were the arm bolts on. 1 is over 3.5inches other is just over 3 that. Were the knuckle was cut and welded
    if the distance is different from where the hubs mounts to the lca arm and where the trackrod bolts on, on both of the hubs your never going to have the same amount of lock on both wheels, who did em for ya?
  4. #14
    i like cake
    Dec 2009
    damn whoever did them should be shot!
  5. #15
    They were done when i got the car
    Quote Originally Posted by chrisb View Post
    I brought faster all way forward on lift just to b sure
    Ya lad the steering joint is hitting the bottom arm when on full lock I brought the whel forward on both sides as much as they could go so I'd have them the same and their still hitting the bottom arms that's Wats stopping me from getting more lock
    Quote Originally Posted by Driftma View Post
    They were on the car when i got it lad. Were ya cut and weld them to his their 2 did lenghts by bout half an inch
  6. #16
    I also ment to add the bottom arms are extended by 50mm also when j got the car is that a bit much?. And if i fit diff arms and extend them by less would this help me
  7. #17
    50mm is excessive, i usually go 25mm
    your main problem is the hubs though
  8. #18
    Ya ill get other ones made up 25mm
    Wats causing the steering arms to hit bottom arm?. Like when on full lock the steering rack is not full locked atal its the bottom arm is stopping it from going more
  9. #19
    Team ManFoot Famous jh's Avatar
    Dungarvan, Co. Waterford
    You've been told over an over your hubs are wrong lad No point debating xy & z til you fuck off them...
    Quote Originally Posted by Greg View Post
    Some say wide wheels and skinny women fear him. Some say vice versa.
    Team Manfoot
  10. #20
    Quote Originally Posted by Famous jh View Post
    Their is 1 hub less than half inch shorter. But still the 2 steering arms are hitting bottom arms. Woudnt it b 1 steering arm only hitting if the hub was wrong?.
    Also if you can't answer me don't reply to my thread
