hay guys need a bit of help have no idea of what make of bearings to buy for a rb20 looking for good after marked one, main and big end. thanks
ACl race series make sure get race series they much better job!!
thanks lads one more what would be a good head gasket see so many 1.2 1.4 1.6 all they do is lower the compression ratio or is there more to it.
If you going changing the thickness of your head gasket you'll have to get the car mapped.. Go talk to your mapper see what he reccomends..
what engine are u doing jay???
If you have to skim the head or block you can use thicker head gaskets to make up the difference, or to use them to change the compression
thanks lad but what is a good brand.
Any of the large makes, Tomei, HKS, Cosworth.
