could any one tell me where the vacume line right under the diagnostic portwhere it is meant to be connected? cant figure it out![]()
[SIGPIC][/SIGPIC]
Just had a look at my 1jz there and the vacume line thats under the diagnosics port on the inlet mani goes just to the left of ur traction control solinoid its the bigger vacume pipe theres a smaller one next to that aswell on the left of that next to the inlet side.
Theres a metal pipe running to it and 2 vacume pipes on each end of it going into the inlet at both ends, could just use 1 length of pipe if u havent the metal pipe. hope that helps
thanks should have said its connected at the throttle body end its the other end i dont know where to connect it to?
[SIGPIC][/SIGPIC]
ti goes to a t at the diagnostic and from there to a unit under the inlet mani
