Results 1 to 10 of 12
    i love lamp cooks86's Avatar
    Feb 2011
    tipp
    Exclamation over heat help asap
    Driving to work this morn in s14 and the temp went up high it usually dont even budge much off zero so anyway went round a round about to get spot to stop and it went down to half way so I kept goin then made way back up then same at next round about so I kept goin then when pulled into work steam came from coolant bottle but coolant levels fine and got service last wk so I have rad topped up with water so what ya think broke thermostat????? Any help thanks
    [SIGPIC][/SIGPIC]
    Kilkenny
    Sounds like its low on water and when the water is curculating around the system there is only enough water to keep the rad full or the block full. Try adding water then bleed the system. Other than that head gasket blowin. Try the simple things first
    Pro Driver
    Quote Originally Posted by keith_b View Post
    as said above!!! sounds like its airlocking!!!!
    Feb 2011
    tipp
    Checked water dere was low thanks lads hopefully dats it
    [SIGPIC][/SIGPIC]
    Kilkenny
    make sure you bleed the system or it will keep happening. Open rad cap and cut a coke bottle in half put tape on the side where cap goes on and wedge it in the top of the rad fill it with water start the car leave it running till it warms up and stat opens you should see air bubbles rising in the bottle. When there is no more bubbles the system should be air free
    di Member Driftma's Avatar
    Dungarvan,Co.Waterford
    or fill the rad, and with the car running open the 10mm bled bolt on the top water hose coming out of the head when you've a good flow of water out of there it should be blead. or evenb just top it up with that bolt open. it all ways works for me
    Jan 2011
    cork city
    have seen rads to block alot on these sr s. as said above bleed it threw the bleed screw first. take it for a spin and see. make sure ur using coolent also. not just water.this happened to my s14 2 years ago. took the rad in to be flow tested and turned out to be half blocked. got rad repaired and good as new.also happened to a 180sx i bought last year. perfect in around town but take it out on open rd for more than 10 mins and it would overheat. turned out to be also blocked rad
    Option 1.... CRACKED turbo water pipe
    Option 2...Blocked Rad
    Option 3...Blown head gasket
    Feb 2011
    tipp
    Ya put water coolant back in is back to normal now just happened out of the blue thanks for all help and advice
    [SIGPIC][/SIGPIC]
    MEATH
    Quote Originally Posted by cooks86 View Post
    Find the cause of loss of coolant!!
