need to know what sr to put in a 98 180sx
redtop/blacktop/vvt ect all help would be appreciated
You need a non vvt kouki blacktop if you want to be specific but a Redtop will do if you are keeping the same loom in the car a vvt will NOT work unless you get something to control the vvt solenoid and modify your map to suit
standard is a blacktop non vvt.
vvt only came in the s14/s15.
thanks for the info lads. what is the difference between a blacktop and a redtop
i will be keeping the loom in the car so a non vvt blacktop wiil go in no hassle
i have a 98 kouki model loom and ecu here ....cheap.....80 notes takes it delivered to your door at that
thanks for the offer but there is a loom in the car already
