Results 1 to 6 of 6
    Default Greedy turbo question
    the oil return side on the turbo, where the oil return pipe connects or is fixed to the turbo. what is the best type of gasget to use?
    would a sealer be a waste of time with the heat?
    Thanks
    May 2011
    ya should use a paper gasket, ya can get it in any motor factors. doesnt have to be thick stuff. never use a sealer on a turbo.. incase it gets loged in the turbo and causes damage...
    Quote Originally Posted by keith_haugh View Post
    thanks lad,
    I kinda thought that would be best method, one of my friends metioned copper but that wouldnt work either, wouldnt seal right
    May 2011
    ya can get a copper washer a fraction of the size bigger than the return hole then just bolt it up. but it'll just leak. 2nd option would be a thin piece of copper sheet and just make a gasket. same job as the paper gasket... id trust the paper gasket more..
    sound man, thanks. help well appreciated!!
    May 2011
    no worries mate...
