got her back from mapping, now to sort the steering, and finish off a few bits and bobs, took a wee video of her,
1ux rx7 with m122 - YouTube
If it ain't a V it aint for me!
savage car man..
the belt was slipping on the charger so I modified the tension so it can be adjusted, should do the trick....
as the gearbox is shorter than standard, the gearstick is further forward and the tunnel had to be cut. here is the patch i put over the gap,
I had a leak from the power steering, and an oil leak from the oil filter plate so i pulled out the rad and intercooler to get at them.
the standard rad was blocked up on one side so I got myself an alloy rad, ebays finest!
I got a hydro cheap off a local rally man, there was a crack in the frame beside the master cylinder. I gave it a run of the mig and then set about makin it a bit more vertical!
If you ever need inspiration
Mad Mike's souped up drifting car - Madbull Generation 5 - First shakedown - YouTube
If It Aint Rubin, It Aint Low Enough
Awwww! mad mikes is a beast, if i had 20k i'd have a 4 rotor in the morning!!
would love to get to the next bishopscourt pete!
