Results 1 to 9 of 9
Thread: 325 tds lsd ?
    Dec 2009
    Default 325 tds lsd ?
    Any one know what or where i can get a lsd diff for
    a 325 tds. Think ratio is 2.56
    Cork
    Unless you find an E36 325tds that had an LSD to take the diff from which would be pretty uncommon, you'll need to just get an limited slip unit from an E36 M3 or any other similar diff and stick it into your 325tds diff.
    May 2011
    castlefin co.donegal
    Would be a huge job ta put a LSD in a 325 diesel
    You would have ta put a full back end out of a 328 or m3
    Your drives wouldn't fit the LSD then then drives that fit
    The LSD wouldn't fit your hubs . To be honest you be better
    Off changing the car for something else a was down that road
    Changing a sierra to a LSD from a cosworth . Or you could buy
    A second standard diff for it and weld up the diff that's in then
    Change them over for the nct/mot
    Cork
    read my first post
    its not that complicated.
    diff straight from a 328/M3 wont work anyway as ratio will be too short.
    May 2011
    Well if the LSD from an m3 /328i fits his casing
    Why not keep his own crown wheel and pinion ?
    but is the 325 not got the small case diff ?
    A have a m3 LSD at home but no casin it came out of
    My own car if ur interested in buyin it
    Cork
    i did say to keep the tds cwp, all you need is the M3 unit
    your m3 diff bits would be perfect for it. id take the cwp off you as nearly every second 3L M3 diff I rebuild has something wrong with it and damage done to the pinion. just shows that they really should have used a large case diff for both 3 and 3.2L M3s
    Dec 2009
    Default lsd
    Thanks for the replys,
    but i'd be nearly sure my crown wheel would'nt bolt up
    to a m3 lsd?
    wonder if a estate 325tds had lsd?
    we put an m3 diff into a few tds just need to put the tds cups and prop shaft flange on the the m3 diff and bolt it in iirc.only down side as daveM-sport says is the shorter gearing but didnt bother us!
    Cork
    Quote Originally Posted by Duck Drift View Post
    to a m3 lsd?
    yes it wil. if it doesnt you can just use a different unit from an E30 or whichever car has the right type of unit.
    just take off the back cover and youll know which type youll need.
    theres small, medium and large obviously and then two types of medium case unit due to having different crown-wheel offset for a bigger pinion gear.
    either unit fits inside any diff but its just that you need to match them if using a particular cwp.
    for example, the 3.64-4.45 medium case diffs have the small pinion and lower offset crownwheel while the 3.46 and lower have the bigger pinion and larger offset in the crownwheel.
