Results 1 to 10 of 27
    Default My 2012 ps13 project
    Finally im getting to start my ps13 for 2012 , i bought the car in 08 and drifted it throught out that year done a few bits to it and early 09 had it up the north for a practise day and the oil pic up pipe broke off in the sump and starved the engine and i ended up makeing bits of 1 of the big end bearings it done a small bit of other damage but not that bad ,so i took out the engine and stripped it and got all the parts i needed to sort it out and just ended up not putting it back together so the car has been lying up since 09 .
    So now im gonna try build it up as much as my funds will let me and try and have it ready for competition in 2012.
    PLAN
    Strip it bare and seam weld it underneath
    Make up a spit for the car so i can get to the underside to seam weld
    Seamweld it inside and engine bay
    Put more bars in the cage and make the chassis as strong as i can
    Spray inside ,cage and engine bay
    Put sr20 back together
    Hopefully get bigger turbo,z32 afm,alloy rad ,fmic,oil cooler
    Get hub knuckles modified , steering rack spacer as many suspention arms as i can afford
    40mm wider front fenders, wheel spacers
    Thinking off getting an rb25 gearbox but have to see about funds
    theres a good bit of other bits i will be doing and ill add to the list as im going along
    If anyone has any suggestions for me as im building please feel free to let me know
    ill update the thread every few days
    heres a few pics of some work i got done on the engine bay today
    I got a nice bit off stuff removed from the engine bay
    ive a question when removing the loom from the car can the loom be removed without having to cut it somewere is there a break in the loom somewere as this is my first time removing a loom from a car
    Croom/Adare Co Limerick
    disconnect it at ecu and feed it out to engine bay
    as for addin bars to cage.. i think u should wait to see the new regs coming out for 2012 cause i think the thickness of the cage itself is changing
    Quote Originally Posted by 180sxbreaker View Post
    Cheers for that id love to strip off any wires from the loom i dont need but i wouldnt be great a wiring
    your rite i never thought about the new regs
    i need to sort out a mig welder for seam sealing ,cage and other stuff ill prob have to hire 1
    does anyone know were id buy a cheap 1 around the country?
    Dublin
    Best of look with the build man.
    Be some rush to get things done if they bring in new cage reg's, imagine everyone trying to book in!
    Quote Originally Posted by si_berry View Post
    Cheers it seems like a long way off getting it finished but i hope to spend everyday at it
    when does the log in usually be?
    april kinda thing but the regulations prob won't be brought out till march..so i'd advise do everything else ya hav to do first
    so many lds goin to be under pressure next year
    jesus that is late that would throw my plans for the car out the window if the cage regs are changed
