Results 1 to 10 of 70
    Team Nocturnal batman026's Avatar
    Corcaigh
    she looks clean, best of luck with her, cheap and cheerful is the way to do it
    Follow us on Facebook, CLICK the picture and LIKE please.
    <a href="https://www.facebook.com/pages/Team-Nocturnal/245958445511099?ref=tn_tnmn"><img src="http://i49.tinypic.com/bhktvp.jpg"></a>
    SM Vehicle Services driftfan's Avatar
    Ballymoney
    Quote Originally Posted by batman026 View Post
    cheers lad
    Leave the car out in the sun for a day or two and the sound-deadening will just crack away and peel off which is great as the glue comes away with it too and doesn't leave any residue or anything behind only nice clean paint.... oh wait, it's Ireland
    Spilling brake-fluid helps alot too in removing it funnily enough as I found out once unintentionally.
    Usual way I do it is just get it soft with the heat gun and just peel it off with a scraper.
    Then use thinners to clean off the shit thats left behind afterwards.
    Its a clean looking 323i! Change the waterpump and stat before you do any hard driving with it anyway as if the alloy engine cooks, its pretty much scrap. Some of the early ones had a plastic impeller pump too that used slip on the shaft which wasn't good but you can get metal impeller versions from most good motorfactors or from the likes of Barrysmotorsport on here.
    Looks like a very straight shell though
    Nice enough colour too really
    di Member Paddy drifter's Avatar
    Oct 2010
    inistioge co kilkenny
    best of luck with the car
    u just talk nice to me or ill tell john to make that cage out of timber and then we see who passes scrutiny
    Ballymoney
    cheers for the info dave! i removed all the sound deadening in the back just need to get the sticky residue off now :P its actully not the same colour as that one its more of a minty green and cheers paddy!
    Oct 2010
    Quote Originally Posted by driftfan View Post
    bug and tar remover i used its good stuff any auto factors should have it and its a nice colour
    Ballymoney
    Quote Originally Posted by Paddy drifter View Post
    have tar and glue remover there that im gonna use tommoro
    di Member JDMep82's Avatar
    Jan 2011
    Ice project man, clean base to start with. Best of luck with it.
    Ballymoney
    Quote Originally Posted by JDMep82 View Post
    thanks man! all comments negative and positive welcome
    Jan 2011
    And I ment "nice" not "ice" ha stupid phone! Coilovers make sum difference
