Results 1 to 10 of 12
Thread: Altezza Problem
    Default Altezza Problem
    My brother bought an altezza about a year and a half ago but has been parked up since.
    Im driving it at the moment but theres a problem with the dash. All the instruments in the dash will go limp out of nowhere when driving, when this happens the car is way down on Power.Tried driving it on when it was in this "mode" and it threw up the engine check light and the traction control light then started flashing.The engine check light goes off if you restart the car but it stays in this "mode" with the dash instruments at zero.
    Its a completely standard car no aftermarket performance bits or anything.
    Anyone had a problem like this before or heard about it ?
    Cheers
    The few I had all did that when the batteries were fooked
    Tried a new battery bought this week and seemed fine but acted up again. Gonna get it diagnosed asap
    Is the charging system working correctly?
    Jan 2011
    My fuel gauge would.just drop and flash like its empty the oil pressure gauge wont work and the outside temp would just read "E"
    luckily it just fixed itself after a while
    Ya seems to be starting perfect all the time never sluggish or anything and the voltage reading is grand and high and stays up when the dials are working
    It could be a bad earth lad. It would be the next thing Id check out if I was at the car. It can be a common problem to have bad earths in older jap cars. Its worth a try anyway.
    May 2010
    Louth
    Quote Originally Posted by pandy180sx View Post
    Cheers
    My Altezza done this simple to fix, open the fuse box in at the engine bay and its the big yellow fuse cant remeber which number think its the only yellow one, take it our for 5mins and put bck in and you will be sorted!!, through a picture up of the fuse box if you want and all know then,
    cheers man will try that there
    ^^^^^ the earths also seem fine but if the fuse doesnt do it ill beef them up a bit
