Hi,
I have a problem the last few days with my s14 i'll try to explain the best I can..
When driving along if the car hits any wee bumps the Air Con display goes blank and the car starts stuttering as if you turned the key off or something although the dash lights never go on or off or anything and if i clutch it the ac display comes on and everything is back to normal.
I thought it must be an earthing problem somewhere but everything seems fine.
Then I noticed that some times i can hear the fuel pump whining and other times not. Once i turn the car off i can still hear a sound from the fuel pump area that i can only describe as if you were standing outside your house and someone was inside hoovering aka the wife. This noise is there even when i disconnect the battery and can be heard for at least a minute very faintly.
So im now thinking it could have something to do with the fuel pump...
Has anybody come across this problem before its doing my tits in and i need to get the car sorted for a drift day at the end of the month
Any help appreciated!
