Page 1 of 3 123 LastLast
Results 1 to 10 of 26
    Angry What Could be causing this?????
    Hi,
    I have a problem the last few days with my s14 i'll try to explain the best I can..
    When driving along if the car hits any wee bumps the Air Con display goes blank and the car starts stuttering as if you turned the key off or something although the dash lights never go on or off or anything and if i clutch it the ac display comes on and everything is back to normal.
    I thought it must be an earthing problem somewhere but everything seems fine.
    Then I noticed that some times i can hear the fuel pump whining and other times not. Once i turn the car off i can still hear a sound from the fuel pump area that i can only describe as if you were standing outside your house and someone was inside hoovering aka the wife. This noise is there even when i disconnect the battery and can be heard for at least a minute very faintly.
    So im now thinking it could have something to do with the fuel pump...
    Has anybody come across this problem before its doing my tits in and i need to get the car sorted for a drift day at the end of the month
    Any help appreciated!
    The pump after turning off i have also . im putting it down to fuel returning to the tank when theres residual pressure after turning off ...
    Quote Originally Posted by bounceae86 View Post
    That could be what that is alright, cheers....now to figure out the main issue
    Donegal
    i was fixing a corsa their and it was at simular shit ,
    need to have the handbrake up one knick so the handbrake light on the dash was on and it would run , handbrake down full and it went like a bag of shit .
    was doin the same with the fog light .
    It was a bad earth . I just made up a good heavy cable and earthed the battery to the body and sorted it out .
    I know you said all earths looked good but its handy to do and might sort it
    Quote Originally Posted by Mac_C View Post
    Cheers lad, ill give that a go
    Donegal
    Sound hopefully that sorts it man cant have ya missing out in derry
    Dec 2009
    Angry s14
    sounds like water/dampness got into the eletronics,
    had weird problems with a e36 tore the hole car apart.
    then open the ecu all corroded
    I know, id be sickened to miss it
    Quote Originally Posted by Duck Drift View Post
    Ill have a look at the ecu but i doubt it would have got damp as its used daily.
    Keep the suggestions coming though as anything i can check to narrow it down the better!
    athlone
    is the loom done like an s13 going along the drivers wheel arch rubbing tyre on bumps?
    as doyler said above mate, either that or a bad earth
Tags for this Thread
