Results 1 to 7 of 7
Thread: what to do next
    Default what to do next
    ii got a cheap 318is e36and im gething the diff welded so what should i do next
    and i was just wondering what do they norumly rev up to
    thanks
    di Member Romo's Avatar
    Wicklow
    Quote Originally Posted by peterhouze View Post
    thanks
    beamers in general aren't to rev happy, get decent coilovers or chop the standard springs and pray for a bitta rain
    Quote Originally Posted by Rob32 View Post
    Your intellictual response to my post was that im "gay" that shows the intelligence were dealing with here
    Galway
    Quote Originally Posted by DeLab View Post
    or find somewhere wit gravel
    Meath
    Quote Originally Posted by way2fastforu View Post
    He speaks the truth! That's the only way I used to get mine to slide!
    Strip it bare too man, the interiors are pretty heavy it'd imagine.
    IS's are one of the rev happier bmws actually, will go to 7k id imagine.
    lash your tyre pressures up too.
    di Member andy t's Avatar
    if you wana tramp it then
    weld da diff
    cut da springs
    strip out anything that you dont need
    & horse it off 6k to get it around
    (did this before wit a 518 that we had lyin
    around & we only drove it on private land in case anythin went wrong cos twas dodge)
    but if you wanna mind it then dont even weld da diff cos it will more that likely give in as i know lads that had da same experience with thier E36's
    Team Twenty !
    SR20 in the front 2way in the back!
    She'd def be rev happy with an M plant on bord LOL
