Results 1 to 10 of 11
    di Member gmaneire's Avatar
    May 2010
    Millstreet, Cork
    Default camber problems...
    Just fitted Driftworks adjustable front camber arms to my R32 and they seem to have made no difference!?
    I was looking to get good negative camber and im just wondering have i done it wrong!?
    probably a stupid question but any help would be great!
    Darren
    did you adjust them there is a reason there adjustable
    Kilkenny
    There adjustable so just shortin them
    May 2010
    Millstreet, Cork
    Quote Originally Posted by peterhouze View Post
    haha im not that bad! but ya they are, to what should be max. was just wondering if there was a trick to putting em on or something, because they look very straight forward!
    di Member Micko's Avatar
    Driftworks upper links give approximately 1.5-2 degs of negative camber which is feck all!
    To get more out of them you will have to fit uprated lower arms or else a cheaper option is s14 lower arms, you should see a difference
    There shite and give fuck all camber for the money.... Throw in a set of s14 or r33 lower arms which will help a bit....
    Quote Originally Posted by DaveZigen View Post
    It takes no talent, sacrifice or commitment to be a critic. Fact!
    May 2010
    Millstreet, Cork
    Post
    Quote Originally Posted by Micko View Post
    pity they dont tell you that when u go to buy them!
    thanks tho, its been wrecking my head all night!
    Yeah i know, have them in my own car the last while, dissapointed with them to say the least.
    Nismo links can give 6-7degs without lower arms apparently
    May 2010
    Millstreet, Cork
    cheers lads..
    get a pair of s14 bottom arms but the front camber arms may need to be modifyied
    between myself, wez & dan moorhead we got to the end of it! Ring wez @ wkdimports & speak with him about setting it up & i can modify them if you need it done! We had ALOT of trouble with them, expecially the passenger side on my own r32!
