Results 1 to 9 of 9
    Mar 2011
    kk
    Default injector question??????
    in a 180sx i have a mis fire in one cylinder. its not the coil packs,plugs,harness for coilpacks and i have perfect compression in each one think it could be the injectors. which injectors are bigger red or purple? and wha size are each?and can you run one red wit three purple ones or is that the prob that im searchin for?
    Jun 2011
    The standard injectors in a 180sx are purple they're 370cc I think, don't know what the red one is it could be anything. I gather you have an odd injector in your car? If so that's probably the problem.
    di Member rico180's Avatar
    Feb 2011
    Formally westmeath,currently calgary, Alberta .
    johnie is right, purple injectors are 380cc. there handy to come by second hand, most lads would swap them out for 555cc, on the run for more power.iam not sure what size red ones are. i think purple are the smallest you can get.
    correct me if iam wrong!!!!!
    Mar 2011
    kk
    nice one lads thought they were standard alright have the fuel rail off it at the min any ideas how to get them out of it??
    its ok got them out
    Sep 2011
    unscrew the top cap with the two Philips bolts , then try moving them by the plug, left to right , you should be able to gently pull them out after a while of moving, if that fails, silicone spray and more moving, they will eventually come out
    Mar 2011
    Is the injector red/brown, if so its prob a s15 one
    Mar 2011
    kk
    got them out an all handy enough sound.no three are jus all purple and the other one is jus red any idea wha size the red is
    di Member jap scrap's Avatar
    Quote Originally Posted by n.sr20ronan View Post
    I dont know but you are lucky you have not got a hole in a piston after one odd injector firing more fuel
    Jun 2011
    Get the make and part no. from the injector and google it, you won't be long finding out what it is.
