Results 1 to 8 of 8
    Default Help front suspension ???
    Ok not exactly sure what it is but when i put the coilovers in a while back i noticed that the driver side was slightly cambered which i thought grand but went over to the passenger side and it was dead straight in fact nearly looked like ther was a teeny hint of positive camber now i checked the coilovers and they are at the same height both sides
    I have also noticed a strong pull to the left, the pull was there before the coilovers went in but i just thought the tracking was off im thinking now that its the upper suspension arm or the rod connecting it to the chassis?? its making a slight rattling noise aswel as im driving
    can anyone shed some light on this??
    Jun 2011
    Where the shock mounts to the hub has camber adjustment on most cars.
    Jul 2010
    cork/limerick
    did u check the ball joints and all the bushings
    Nov 2010
    Cork city
    have your top mounts got camber adjustment?
    Jul 2010
    Meath
    Did u check and see are any of the arms bent or something?
    Dec 2009
    Offs lads.... Ur car needs to be set up.... Get it tracked and if u have any other arms get the suspension set up properly....
    Quote Originally Posted by DaveZigen View Post
    It takes no talent, sacrifice or commitment to be a critic. Fact!
    Jul 2010
    Meath
    This is another possibility
    Dec 2010
    kerry
    get the wheels aligned and tracked if that dnt sort it they will knw the problem
