Results 1 to 7 of 7
    di Member fitzygtr's Avatar
    Apr 2011
    Cool Ecu mappin problem.
    Well lads havin a problem just gettin my car mapped at minute but havin problem's gettin ecu to store new map the ecu wont power off when ignition is switched off have any of you ever come across this problem. Its on my skyline 33 gtr. And its an apexi power fc ecu.
    Tuner should know whats up with it
    There was a thread about this before fecked if i can remember what it was tho.. Did u jump start the car with the ecu in it?
    Site Trader: TDP - Trackday Performance
    Quote Originally Posted by fitzygtr View Post
    There are 2 options.
    The ecss self shut off circuit on the car is not working and the power fc cant commit the map to the memory.
    The power fc has had reverse battery polarity and the memory has been damaged.
    Your tuner should know how to do it. If not may be they lack the vehicle and ecu experience needed to get the best results.
    Robbie
    Apr 2011
    Wink
    We have put in a brand new ecss relay made no difference and put in a brand new power fc and made no difference. There was an alarm in this car before and i took it out cause it was drainin battery and it was just a rats nest of wires anyway i'm wondering the crowd that fitted it do anything.
    Senior Member paulr5's Avatar
    Oct 2010
    Takeshi's Castle
    Pot, kettle, black??????
    Id say they wired it direct to an ignition switch
    If the power to ECCS and coils are taken from the Ignition the pfc wont have time to save your changes, so it will be stuck in a read only mode and won't store your changes or "commit......."
    Replacing the relay isnt even half the battle. Gtrs have 3? 12v+ supply/back up sources pin no 43, 45 and 58?
    your alarm removal could have messed up a supply, check the pins above first, had it happen on an s14a before simple enough fix
    Where's it based?
    Originally Posted by sc86
    better thread would be pics of all the savage jap cars parked up hidden around the country in sheds!
    No because whores like you will buy em and break em
    Quote Originally Posted by paulr5 View Post
    Where's it based?
    Same thing happened my r32.
    1 power wire was not going through a relay ,so wasn't giving the delay necessary to save changes.
    When you turn the key off ,you should hear the relay click after a second or 2.
    Apr 2011
    Wink
    Thanks lads - i am heading up to the lad thats mapping it tomorrow and will try what ye have suggested and let ye know how I get on.
