Results 1 to 6 of 6
    di Member Bennyk1122's Avatar
    Default Thermostat querie
    What are the disadvantages of running without a thermostat? Thinking of taking mine out
    Feb 2011
    cork
    you dont want to be doing that, it will take far too long for your car to heat up =bad because it will increase component wear significantly and bad for fuel consumption .
    why do you want to take it out is your car over heating, if so do you have coolant not water in your system,when was it last changed?
    is your thermostat jammed ?(to tast take it out and put into a bolling cup of water to see if it opens)
    Senior Member paulr5's Avatar
    Oct 2010
    Takeshi's Castle
    it's a short term solution to a long term problem,
    The last day out in Ballbrigan, I pulled a thermostat from an sr after the rad got damaged, wanted the car to last another session, it heated up just sitting in the que so no more than 5 mins, (and blead the system properly)
    If it's a toyota don't take it out, they overheat at the best of times,
    Originally Posted by sc86
    better thread would be pics of all the savage jap cars parked up hidden around the country in sheds!
    No because whores like you will buy em and break em
    Pretty good explanations here why you should not remove the thermostat:
    http://www.driftworks.com/forum/tech...hermostat.html
    I'll not bother then lol, the car was running about 90 degrees on after a couple of laps, just thought it might be an option I'll just upgrade the fans and vent more air into the engine bay, thanks for the help lads
    get a big rad if you havnt got one already
    E85 Powered 355bhp S14A
