Results 1 to 3 of 3
    Default sr20 gearbox question?
    Have i got to do the dreaded job of removing a gearbox to fix a shitty mistake
    anyway just bought my first sr20 and thought it best to change the gearbox oil but instead of removing the fill bung i removed the bolt that holds the selector fork in position? anyway im just wondering if anybody did this before and can it be put back into position without removing the gearbox?
    di Member thegosson's Avatar
    Is it the wee ball and spring yolk that you opened? The retainer lad that stops the gear selector from slipping in and out of gear? Sits into either one of the 3 indents on the selector shaft........?
    Quote Originally Posted by thegosson View Post
    not to familiar with the gearbox lad but i found a link to that is exactly related to what i done
    http://www.miata.net/garage/tsb/s05_112_02.html
    hope that explains it a bit..
    im just wondering is there any possible way to put it back in position other than removing the gearbox?
