Results 1 to 8 of 8
    Jul 2010
    Meath
    Default Difference between SR20 non vvt engines???
    Hey Guys,
    This topic has probably been covered before but I couldnt find it. Iv a few questions and I hope yea can help me.
    Iv a couple or spare engines in the garage, a SR20DE and a SR20DET.
    1) How can I find out if the SR20DET is a redtop or a blacktop??
    2) Are both the SR20DE and SR20DET (with the exception of the pistons) the exact same e.g. head, block, crank, cams, oil pump etc
    3) Would the block of the DE engine be suitable for a spare if a cylinder is scored in a DET or is the DET block different?
    Thanks for the help in advance.
    Joe
    de and det blocks are different.
    vvt to non vvt blocks are also different you can use a vvt block with a non vvt head but not the other way round
    cranks are all the same
    you can use a de head with some work
    difference between red top and black top, there are slight differences, easiest is to check the oil pickup
    Jul 2010
    Meath
    Thanks Chris, so what usefull bits are on the DE engine before i scrap it?
    Member
    waterford/kilkenny
    most of it,especially the cams
    085 8894526
    Jul 2010
    Meath
    Quote Originally Posted by jamie180sx View Post
    Most of the DE is useful yea??
    Member
    waterford/kilkenny
    yes it is
    085 8894526
    head and crank
    Junior member toyotagt's Avatar
    are they different then turbo ones?
