Results 1 to 10 of 59
    killarney
    Default camber wont be enough!!!!
    so, i bought these clearly knowing id have a slight issue
    the fronts are perfect offset (18x10 +6) for a 40mm origin wing.
    the rears on the other hand with 50mm origin overfenders are em...... slightly different....
    now..... origin dont do 70mm overfenders even 70mm wouldnt do.
    suggestions anyone?
    dont think the rocket bunny kit is wide enough.
    bn blister kit do?
    Senior Member subzero's Avatar
    Muunchster
    fronts are spot on .... bn blister rears would look unreal .
    Quote Originally Posted by subzero View Post
    With a blister kit u need the full kit as the sideskirts slip into the front wings and the rear 1/4s...!
    Quote Originally Posted by DaveZigen View Post
    It takes no talent, sacrifice or commitment to be a critic. Fact!
    killarney
    true as fact lad, cant be got for a sileighty either unless the parts are bought seperate.
    only come for the 180sx or ps13.
    killarney
    they look like 25mm mate
    i got 50mm last week and they look alot bigger then those
    s14a i have
    my wheels on the s13 stuck out nearly that far before camber , you gotta get camber arms and remove them bolts and wind them all the way in. i do not reccomend this but thats what i did
    or go bn blister 70mm arches
    Them over fenders are not 50mm....! Iv a bn kit and there 50-60 max and there are way wider then them 1/4....! Wheels would fit no problem under an actuall 50mm 1/4...!
    killarney
    they were bought as 50's and measure 50mm from the metal quarter??!
    di Member NIALL JZX's Avatar
    tipp
    ya they look more like 25/30mm lad.. ??
    lookin at the filler cap , it looks like the quarter is out abot 25mm like an over the wheel looks like its jus following the natural lines of the body if u get me?
    maybe im wrong but they jus dont look like 50mm from that angle in pic anyway //
    formally drifter
