Results 1 to 4 of 4
    May 2010
    Louth
    Default S14 New Clutch Help
    Put a Standard Clutch in a S14 there for a mate car is standard, pedal is awful light compared to any other s14 ive had, Its the 1st clutch i have fitted to a S Body , car is driving fine with it but there no pressure on the pedal at all!! Any Idea's
    di Member boost-addict's Avatar
    Apr 2011
    Dublin
    How light ? I know when I first got my 200 with a standard pedal it was lighter then a new Micra clutch... It hardly felt like I was pressing anything. It bit quite low as well Clutch has been in a few thousand miles so far and is still very similar, has stiffened up a bit but not too much.
    It's hard to compare but I just know that when I first drove mine with a new(ish) clutch (~2k klm) it was lighter then any car I had driven before.
    di Member lsd32's Avatar
    A new standard clutch and pressure plate will give a very light pedal,most s14s have 15 year old pressure plates that are fooked so the pedal will be heavy,light is normal
    If you think you can,or you think you can't,your probably right!
    www.ryansautomotive.ie
    Change to a better clutch...Over the counter ones SUCK!!!
