Results 1 to 5 of 5
Thread: HKS EBC Iv
    Default HKS EBC Iv
    Have a HKS EBC Iv,
    Just want to double check i have the vacum lines in the right place,
    1. Vacume onto the inlet manifold after the TB,
    2. Another Vacume onto the actuator
    3. Vacume onto the boost pressure from the turbo to the intercooler (see photo below) Just want to make sure i have this line in the right place that its 100% ok,
    also standard boost on a RB20DET is it .7 bar Cant drive the car atm to check...
    ell bumpo....
    has all the lads with the knowlegde & info run away & disappeared
    Jun 2011
    yep that seems about right from memory, I had one of these 5-6 years ago, in a r32 gtst.
    Quote Originally Posted by Johnie View Post
    Cheers, i was 99% sure it was right
    Jun 2011
    No problem, I think it makes a difference which one of the fat pipes goes where, but if it doesn't work just swap them around. .7 bar sounds right too, I don't think the standard turbos can take much boost though.
