Well lads was putting the new manifold and turbo onto my 180 and the back bolt sheared off in the head. i managed to drill a hole in threw the middle of the bolt but its too tight for easy outs.
Does anyone have any ideas???
drill it 4mm and tap a 25ish torqx but into it and slowly go forward and backwards. or drill it out completly and use a helicoil...
must try a torque tomorrow had non with me. would it be safe to put a small bit of head around the bolt??
wouldnt do it myself, but ya could try it. not 2 much heat.. is there any of the bolt stickin out????
it about 1mm inside iti wont bother with the heat knowing my luck it would prob fuck it all up
have ya got helicoils???
yer wastin yer time drilling it man, you need to weld a nut onto it and turn it out, happens all the time, shitty nissan studs!
As alan said get a nut place it over the bolt and puddle it in with a mig welder. The heat from welding it will loosen the bolt if your lucky. Just let the bolt cool for a minute and try turning then. Have a few nuts handy because if its that tight you'll ring off a few. The weld will only stick to the bolt not the aluminium.
My S14 Rollin shell For sale
http://www.driftireland.com/forum/sh...ad.php?t=31509
