Results 1 to 9 of 9
    Dec 2010
    kerry
    Default help broken exhaust manifold stud on s14
    wel lads id a blow in da exhaust manifold and i took of the manifold to discover a stud was sheard the stud is just a bout flush with the head ,its on a s14 and it is the stud neariest to the bulk head how the f??k am i goin to get it out.remember lads its the stud closest to the bulk head its serously tight has any 1 done dis by weildin sum ting onto it
    Galway
    weld a nut onto it an it'll twist out!
    Senior Member paulr5's Avatar
    Oct 2010
    Takeshi's Castle
    Try a 3mm cobalt drill bit down the centre then 6mm and re thread the hole for a new stud, no b&q hss bits.
    If it's snapped flush its the easiest way, cos it'll be prob be seized and a welder wouldnt agree with the head I'd say
    Originally Posted by sc86
    better thread would be pics of all the savage jap cars parked up hidden around the country in sheds!
    No because whores like you will buy em and break em
    MEATH
    Better off sending it out to be done,
    its not low enough!
    Apr 2010
    galway
    Quote Originally Posted by paulr5 View Post
    weve done it loads, drilling it is a disaster as its the furtherest back one he said has snapped! welding onto it is the only way, i had to take 6 out of my skyline! the weld wont stick to the head anyway so itll just stick to the stud, ud wana b a decent enough welder thouugh!
    Galway
    dont drill it at all 97% chance it'll end up in a shite!!!...weldin it is the only way an if not the head will have to be takin off to get the stud milled out
    Dec 2009
    Don't even need to weld bang 2 nuts on it turn the inside 1 it will twist then...!
    Quote Originally Posted by DaveZigen View Post
    It takes no talent, sacrifice or commitment to be a critic. Fact!
    Dec 2010
    kerry
    its sheared flush to the head and its very tight if im going drilling i,l av to use an angle drill
    Dec 2010
    kerry
    the stud is sheared flush to the head
