Results 1 to 7 of 7
    May 2010
    Default Will an S14 diff fit a 180sx
    Probably been asked loads already but cant seem to find any answers!
    Will my diff from a 94 s14 fit a 97 180sx?
    Galway
    it will as long as the 4 bolt back cover is used off the s13 diff
    yes most nissan diffs are interchangeable, only difference is the rear casing as said above. the s14 is 2stud and 180 is 4stud i tink, s13 and r32 are also have 4studs on casing
    @poc are you talking diff or diff plus casing?the s14 afaik is a 3x2 outputshaft and the 180 is 5 stud outputshaft depending on the diff itself you might not be able to pop out the output shaft and put in standard ones as some come with specific outputshafts nismo diffs are the ones i think that come with their own outputshafts i came across this problem before when fitting a diff for a fella
    May 2010
    Ya I've read about the back casing
    Tweek, the whole diff with casing. But if all fails can the diff just be put into s13 casing?
    as above you would have to look at the two output shafts.pop off the output shafts on either side to compare with the other output shafts you will be looking to see if the splines are different remember that the driver side output shaft is a different length to the passenger side (the part that slides in to the diff that is)
