Results 1 to 8 of 8
    di Member Mongey's Avatar
    May 2010
    Default R32 fuel pump no live?
    My fuel pump isnt gettin a live,relay is fine,pump works grand,and fuse isnt blown...anybody have a clue of what it could be?
    di Member Quealy's Avatar
    Whats the problem so if its working fine?
    "...OUR SMOKE WILL BLOCK OUT THE Sun..."
    wire split or broken anywhere along the line or have ya looked??
    May 2010
    it works grand when i take it out and connect it to a battery!
    yep traced the live wire but cant find a split anywhere,but where it connects the female reciever is a bit burnt and blackish
    Quote Originally Posted by Mongey View Post
    bell the live out with a meter make sure your getting continuity , id clean that female reciever too. either break in cable or bad connection man
    try running a temporary piece of wire from relay to fuel pump to try it.... sounds like a break in the wire sumwer.....
    Get ya now man, theres a box up inside the drivers quarter that controlls the pump, its not just the relay, it has a 4 wire plug going into it, anything fuckered there?
    di Member tamtaf's Avatar
    Dec 2010
    Maghera
    Quote Originally Posted by Quealy View Post
    I always thought that box was a relay Can you not just hard wire the pump using a new relay to save any hassle??
