Results 1 to 10 of 10
    Jun 2011
    Default 180sx 4 to 5 stud hub conversion
    Hi lads, I know this prob been asked before but I want to convert to the five stud hubs so I can get nicer wheels, i dont want bigger breaks or anything, so would all i need be just the s14 hubs and discs and the front lower control arms, and would my 180sx breaks go straight on to s14 hubs and discs?
    Thanks
    Site Trader : Premier Performance Cars
    monaghan
    you dont need any arms just the hubs and discs and the 180 rear calipers are the same as the s14.
    www.premierperformancecars.co.uk
    di Member thegosson's Avatar
    S14 disks are much thicker than s13 ones so no your s13 front callipers wont do. When I did my 5stud conversion I got the light weight callipers off a z32, which turned out to be off a non turbo z32 and they wouldn't even fit the s14 front disks. So got some off a turbo z32 and they fit perfect. So my advice is to get light weight z32 turbo front callipers and the rears are the same on both turbo and non turbo so either will do. Z32 turbo front disks are the same as s14 front disks so either will do. And depending on your hand brake setup either z32 or s14 rear disks. You only need the front lower s14 arms if you actually using the s14 hub knuckle and spindle , but if you just got the hubs and pressed them onto your own knuckle and spindle you won't need the arms.
    Oh and if you do use the s14 knuckle/spindle you need to make up inserts to narrow the holes where the coilover mounts to them. You can see what I did on my build thread. If you have no acces to a machine shop I think I remember seeing www.frsport.com sell the little inserts.
    Jun 2011
    Thats a great help, thanks lads
    Jun 2011
    kildare
    just wondering, i'm fairly sure i've seen an article on the difference between s13 +s14 lower ctrl arms. although they look similar it said that they are not exactly the same and that this slight difference was dangerous on a road car. i later seen controll arms on ebay that were 'modified' to suit s13 5 stud hub. i think the article was on nissan silvia.com. i'll see if i can find it
    Jun 2011
    kildare
    sorry, its ok. the article on zilvia was about swapping spindles and lca's. your using both, so its cool
    Jun 2011
    kildare
    so could you use s13 coilovers on a s14 by using those inserts?
    why not just get 4 to 5 stud spacers
    Jun 2011
    kildare
    Quote Originally Posted by SUPER 180 View Post
    yea, you said your not worried about upgrading brakes so y not.
    b a shame to see nice 5 bolt wheels with little single piston caliper behind them, especially if its 1st generation calipers. they are only 257mm discs
