Results 1 to 6 of 6
    Default Setting up Greddy Prospec B
    Have one of these in the s14a and need to get it setup right cause its wrecking my head
    On low its going up to .63 bar and then surging on an off on open throttle!
    On hi its going to 1.22 bar and dont want it running that high unmapped.
    Has anyone here got a good setup that they find to work ok on an sr20det without surging etc
    Found this but more specific for an Evo and the fact that I dont have an instruction manual for it either:
    http://www.sr20forum.com/turbo-guide...b-spec-ii.html
    I have had two profec b spec 2s go faulty I think iangsr20 on here had one go faulty aswell.one of mine used to spike the other wouldn't hold boost then died,both of them were set up properly by a tuner.I am now using a avcr and have no issues.it's a good possibility that your controller is the problem.I can't offer much help other than that.
    Shite!!
    Have an AVCR in the FC I might see about using so if I cant get this thing running right!!
    di Member tbk's Avatar
    Heres the manuals for all the greddy boost controllers paul
    They might be of some help
    http://www.greddy.com/tech-support/profec-boost-control
    di Member g6mmc's Avatar
    can u take it to bradley, he'll sort it in about 15mins ?
    di Member doug's Avatar
    Feb 2011
    clare
    if your stuck for abook i have mine here, im in limerick most days, ive to set mine up 100% since fitting the front mount the boost raises over what i have it set to
