Results 1 to 10 of 11
    Jul 2010
    Tipperary
    Default cage regulations
    well lads whats the story with the roll cages for prodrift. There no bolt in cages next year so what are the regulations for next season. This would be great help to me any many others id say..
    Jul 2010
    Meath
    All info is on the PD website
    • All competing cars must be equipped with a 7 point or better roll cage. All Cages may be manufactured from seamless T45 or cold drawn steel tubing. All main frames regardless of material should be constructed from 45×2.5mm, 50×2mm tube minimum. All additional diagonal and brace bars must be constructed of 38×2.5mm, 42×2mm. A manufacturing tolerance of 0.1mm in tube diameter will be allowed, an inspection hole of 3-5mm should be drilled in a non-critical place on the main hoop for wall thickness verification.
    • Joints should be Notched and form fit properly, no flat or crimped joints of any kind.
    • Welds should be continuous 360’ around each joint in the entire structure with no cracks and fusion must exist between weld metal and base metal.
    • The main hoop shall be one continuous length of tubing with maximum of 4 bends, bends must be smooth and no evidence of crimping or wall failure. It must be as near the roof and sides as possible.
    • Side hoops/front legs must be one continuous piece of tube with no joins and should have a maximum of 3 bends, it must connect directly to the main hoop and follow the roof and A pillars as close as possible to the plate/box on the front floor/sill of the drivers compartment. They are to be connected together by a single horizontal tube across the top of the windscreen.
    • Door impact protection bars are required on both driver and passenger side. Cars with Lightweight or fibreglass doors must have double door bars consisting of 2 parallel door bars with 2 small vertical tubes joining them, Or an “ X ” door bar.
    · Hoop Rear Stays: The main Roll hoop must have two rear stays extending towards the rear of the vehicle and connect to the chassis rails or suspension turrets. It must connect to the main hoop within 100mm of the front leg joint and must be a continuous straight bar with no bends.
    • Mounting Plates/box’s must be minimum 3mm thick, it may be multi angled but must be a minimum of 20’’² surface area. ie,(5’’x 4’’ plate). If the roll cage is bolted in then it must be securely reinforced with an anchor plate and backing plate sandwiched on each side of the floor plan with minimum of 8mm bolts of a 8.8 grade or higher.
    • If the front cage uprights are bent in towards the driver they must be braced to the side impact protection bars on the apex of the bend.
    · Additional bracing is allowed but must be of the same quality as the rest of the roll structure. Any design outside of the parameters stated must be inspected and approved by Prodrift technical scrutineers before competition. Whose decision shall be Final.
    Jul 2010
    Tipperary
    i have read that lad but there is talk that there is going to be more changes to the cage regulations
    di Member jdmjimmy's Avatar
    Quote Originally Posted by patt View Post
    why ?? because there is so many people being hurt with current cage specs??
    Jul 2010
    Meath
    Just get Roco to make you a cage. Simples!!!!
    Jul 2010
    Tipperary
    Quote Originally Posted by pole drift View Post
    i will be getting roco to do the cage just put this up so evryone else can know whats happening
    Jul 2010
    Tipperary
    will have wait till someone from prodrift or that tell us the regulations for next season
    Cork
    I've heard that cages will have to have more than 7points + will have to have x door bars.
    It would be better if we got confirmation of any changes now ,rather than having to modify cages next spring.
    Also if there is to be changes to allowing the bulkhead to be cut etc.
    Jul 2010
    Meath
    Quote Originally Posted by Cooldrft View Post
    They will tell you next year 2 weeks before logging!!
