Results 1 to 5 of 5
    Team Nocturnal 20vees's Avatar
    Feb 2011
    cork
    Default standard fuel pressure sr20det? afpr
    i got an adjustable fuel pressure regulator and i was told 10% more pressure than normal would be fine not to damage injectors.
    i used the search function and couldn't find anything, does anyone know the standard fuel pressure and or give me some advice on the setup or in's and out's that they have experienced with adjustable fuel pressure regulators, thanks in advance.
    Click on the picture please like and share our page thanks
    3bar afaik is the standard fuel pressure on a sr20det
    di Member lsd32's Avatar
    Standard pressure is 2.94 bar with out vacuum at idle and 2.45 bar with vacuum
    If you think you can,or you think you can't,your probably right!
    www.ryansautomotive.ie
    Feb 2011
    cork
    thanks for the information lads
    Jan 2011
    cork city
    have a drift works reg in my 14 and running 3.2 bar with out vac and 3bar with vac...
Tags for this Thread
