the buddy owned her before, it used be the cleanest one around
good luck with her man
Looking good Simo. Agree with Ste front looks perfect
sweet project keep up the good work
put on wings to fit and leave the front bumper! it'll look so much lower with it!
bit of work and it will make a cool car!! best of luck nice vs-kf's
will be following this build best of luck with it, i agree with jimmy those vs-kf's are sweet if you ever wanna part with them give me a shout.
***UPDATE***
Well went at welding in the new bits of metal over the weekend and smoothing it over, have N/S 90% done just needs bit more sandin and grinding the O/S piece is in thats all i got done, happy enough with the work seen as i havent choped and fabricated much b4 not the cleanest welds i know but its strong and serves its pupose, i also welded the engine bay skin to the plate so its welded both sides of the turret for best strength.
N/S Work
O/S Work
good look with it.
Just a quick update ill have pics tommorow.
have the engine bay finished and primed, also primed the subframe and the arms etc had the gf helping sand the subframe down 2 !!! next thing to do is pick a color for the engine bay and subframe arms etc then throw the engine in an get it running and go from there!!!
***UPDATE***
well lads fogot the camera for ages so heres a few pics have a bit done mostly to the front end.
Heres the engine bay done and primed happy enough with the way the inner wings turned out.
Caroline cleaning the subframe down with the wire wheel!!!getting stuck in which is gud!!!
