Page 6 of 16 FirstFirst ... 45678 ... LastLast
Results 51 to 60 of 152
  1. #51
    Would look unreal on all 4 wheels you used to have on the Rex, nice work!
  2. #52
    di Member SIMO's Avatar
    Tipperary
    That style wheel would be cool alright but the offset and width arnt upto the style of the body i want with the widebody,so the works are staying on it as they work well with the style low and wide!!
  3. #53
    Tipperary
    Quick update,
    Decided to put the engine and box in today, had to put the new brake line in first then dropped the engine in and put the box on,usually put it in together but didnt want to scrach the paint, mite have it going tomoz if ive time,putting a standard inlet and rocker cover on for now till i finish sanding and polishing the other ones.
    Heres a few pics.
  4. #54
    Tipperary
    Did a few bits this evening, fitted the prop,connected the sensors on the gearbox fitted the fuel filter and pipes.will do more tomorrow!!
  5. #55
    Tipperary
    Well lads have a small update here, got the engine ready to run now just have to finish polishing my rocker cover and throw it on b4 ill start it tonight hopefully. Did the following yday,
    -Fitted i/c and polished piping,
    -Polished thermostat housing and top right coolant elbow then fitted them,
    -Cleaned rad and fitted that with all pipes,
    -Fitted induction pipe and air filter with afm but need to make a bracket up b4 its right,
    -did few other niggly bits.
    heres some pics of the engine so far
  6. #56
    Tipperary
    Was at the car this morn and finally have it running, had no spark which was easily solved with a bad earth on the coilpack loom that was grand then no fuel so traced it back to bad wiring on the pump so that sorted that and it started first turn after that, happy out.Now ive to put the brakes on and bleed the lot.will prob do that tonight and cut the exhaust and re-angle it to get it sitting as far up as i can under the body with a small bit of room for play then ill go for a spin tomoz!!!
  7. #57
    Tipperary
    well lads just finished polishing the rocker tonight,looks savage imo, have to do something wth the coilpack cover not sure yet!! The pics are shit cuz flash kept coming on then batt died once i changed the setting to auto.
  8. #58
    Galway
    jus read through the whole thread there some good work goin into it dude
  9. #59
    Tipperary
    Sound man its turnin out well so far, going down today to do the brakes and re-position the exhaust and other bits prob have more pics tonight.
  10. #60
    Aug 2010
    nice and shiny!!! looks deadly man
