Page 12 of 16 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 152
  1. #111
    di Member Paudie.P's Avatar
    Feb 2012
    tipperary
    cuming together well lad
  2. #112
    di Member SIMO's Avatar
    Tipperary
    Well lads did a bit more work on the arches have passo side nearly done and started on the drivers side have it all coated to prevent rust and metal filler used to seal it up and flush it over. have plenty off room to get my wheel up under the arch so happy out!!!
    Both skins welded together
    Metal filler applied
  3. #113
    Tipperary
    Wheel pushed up into arch
    Drivers side arch marked out
    Happy auld arch
    Arch cut out
    Inner arch slotted
    Arch Folded up to new arch
  4. #114
    Tipperary
    well just a quick update, welded the arch up and cut off the slats, just have to do abit more welding inside the arch then rustproof it and smooth it over.
    Never got the origin rear quarters in the end they didnt come in the shipment i waited ages for, but hopefully picking up a set of the type 2s at the end of the month and then the bodywork can start to finish off and get the car painted. Will have more updates soon.
    Tacking the slats up to the arch
    Welded the seams up.
    New arch just needs grinding and finishing off!!
  5. #115
    Jun 2011
    galway
    looks good man.. comming on well.
    hows the eye???
    an opinion is like an arse hole every 1 has 1
  6. #116
    Tipperary
    Haha not too bad havent touched the car since i hurt the eye wit shrapnel, going to tidy the shed today and get cracking doing other little jobs,cant go welding till tuesday to finish the arches.
  7. #117
    Jun 2011
    galway
    iv been flat out all week had to wire in a omex 600 and map a rover200 that is converted to rwd running a opel redtop and subaru running gear
  8. #118
    di Member ger15's Avatar
    Coming together well Simo looking forward to seeing it finished
  9. #119
    Tipperary
    Started lining up the front end while im waiting for the rear quarters, need to get the front bumper bar to hold up the front bumper but started drilling holes and lining them up.
    Looks nice and wide from the front imo, have to do alot of work to get enough camber so the works will fit under the wings!!
    Need to pull the front up on the bumper
  10. #120
    Galway
    Looks unreal mate! Nice project and attention to detail is brillant.
