motec m800 with advanced functions.1mg of login.serious inquiries only.ring 07786373594 for more details,genuine reason for sale![]()
MoTeC’s benchmark M800 is a versatile, race-bred ECU that is suitable for almost any application including modern engines with up to 12 cylinders. It also suits rotary engines with twin, triple or quad rotors.
It offers maximum sophistication to control the latest automotive advances, such as continuously variable camshaft timing and drive by wire throttle, while maintaining the flexibility to suit a range of users.
This highly advanced ECU is ideal for professional motorsport and integrates seamlessly into a complete engine management and data acquisition solution.
Basic Specifications
Outputs
•8 x Injector outputs—high or low ohm ‡
•6 x Ignition outputs ‡
•8 x Auxiliary outputs—for functions such as camshaft control, drive by wire throttle, boost control, nitrous injection, idle speed stepper motor and many more
‡ Optional injector / ignition configurations:
(requires 10/12 Cylinder Sequential upgrade)
10 high ohm injector outputs and 4 ignition outputs
12 high ohm injector outputs and 2 ignition outputs
Inputs
•8 x Analogue voltage inputs—fully configurable including custom calibrations
•6 x Analogue temperature inputs—fully configurable including custom calibrations
•2 x Wideband Lambda inputs—for Lambda measurement and control
•4 x Digital/speed inputs—for wheel speeds and function activation
Communications
•1 x CAN
•1 x RS232
Physical
•Case size 147 x 105 x 40 mm
•Weight 500 gram
•1 x 34 pin and 1 x 26 pin waterproof connector with gold plated contacts
Advanced Functions
•Traction Control and Launch Control (2, 3 or 4 wheel)
•Gear Change Ignition Cut (flat shifts)
•Overrun Boost Enhancement ‡ (anti-lag)
Enables boost control to reduce turbo lag and improve throttle response in tight and twisty stages for turbocharged cars, specifically in rally events.
‡ Overrun boost enhancement is available separately or as part of Advanced Functions.
