Results 1 to 4 of 4
    Default few problems... r32 gtst
    few problems i have......
    highbeams wont work at all, even when i pull the lever back to flash nothing happens, and the light on the dash wont come on....would it be a problem with the relay as the fuses are perfect and the other lights all work??
    second is my brake lights none are lighting checked fuse and it was blown, replaced it and touched the pedal and it blew again, took out all bulbs and replaced one by one with new fuse and never blew...all 4 bulbs in hit the pedal nothing happened, turned the car on and hit the pedal bang the fuse blew, could it just be a wiring problem as the switch seems to be working....
    cheers in advance for any info
    its not low enough!
    sounds like yer headlamp switch man! had same prob with my back lights that was the prob! also could be your loom running through wheel arch ! gets frayed by the wheel!
    Took apart all my switches in my old 32 and cleaned the connections and they worked fine after
    ur stick for lights and indicators could be dodgey, had a prob before where they stuck on fulls but wouldnt dip worth a try if others dont work
    rear lights sounds like a pos is touchin to earth or the car somewere causin an instant short - circuit
