im looking for a set of injectors for a transit connect,
its a 1.8tdci, 03. it has the delphi set up not the bosch.
anyone know where i could get a set cheapish?
or even a second hand set would do.
cheers mark
cheers mark
corry engineering in midlands can recondition them.. just label each injector for each cylinder. and write down the part number for each injector corresponding for each cylinder, and it should start when there fitted..
otherwise to replace the injectors in the ford brand, you have to code in each injector wheter its brand new or secondhand
have you a number for them lad? i've rang two places already
today and the prices there quoting are crazy. i did a leak test on them
earlier and 3 of them are fucked so to get those 3 reconditioned
is going to cost around €510. and yeah i know about coding them and all
that jazz but cheers for the info.
Paul - 0872402068
Tell him colm sent you!
He programs injectors & pumps & should have injectors there aswell!
Yeah give us a shout there 043 6675054 or info@corryautoengineering.com
Im doing at least 3 sets of FORD TDCI/RENAULT DCI injectors a day,crucial thing is make sure you have eveything spotless clean ie tank,lines and new fuel filter because these block up with the slightest sign of dirt/water
Not digging at anyone else that is 'reconditioning' these injectors but we one of only 3 offical Delphi factory approved and trained Diesel Centres in Ireland and only geniue parts are used and recalibrated to OEM factory specifcations.
Ray
