Yo, i have 550cc injectors on a r32 rail here, can they go on without being mapped?? will they still flow the correct fuel?
Cheers!
Cheers!
no. well it didnt on mine due to over fueling. grand ticking over. when went above 4000 rpm started to splutter.
not without a map,but maybe with a reg ya might be able to improve it
Drifting:Because soccer,tennis,football ,hurling etc only require one ball.......
-Driftireland Perth Rep-
no dude wont work. The ecu will keep sending the signal to feed what it thinks are your current injectors so giving you whatever % too much fuel.
Lowering the fuel pressure mightnt be the best idea either, the injectors need a certain amout of fuel pressure to work properly.
edit: if youve got a power fc or something easy to hook a laptop upto you can change the settings easily enough. but still you should get a map to keep it running right and safe
bollox!! well thats me bolloxed still. thanks anyways lads!
If you have a power pc and commander then a couple of quick sums will get it running for now, work out a rough precentage for how much bigger the new injectors are then standard and then reduce the duty cycle by approx the same amount and you should be able to run reasonably well. still wouldn't go near a track without a map though.
www.inoc.ie
Irish Nissan Owners Club
Bin the lot n put a pair a carbs on it ! Hahah just foolin, injection all the way !!
wasting ur time changing anything with fuelling unless you are goin remapping
