i am running 6 but i know some one who is running 8.5 and doing well on it to
right to get back to this topic and to bump it with a quick and rough set up heres is the camber im running to fit under the front arches
with this set up by eye and roughly from lock to lock and hitting the anti roll bars and tension rods on each side ive to full turns of the steering wheel lock to lock at this ive also moved the tension rods in more and the anto roll bars modified front anti roll bars etc
so far this set up has being tried and tested on a s14 and ps13 and is working good from feed back i am hearing with the only complaint so far is the wheels locking when it hits the anto roll bar and tension rod which is supposly not much so maybe bump stops would cure this
few more pics of mine atm not fully set up
