Right had balls all to do today so decided to take a stab at hooking up some sleepy eyes, anyone who hant done this yet - doooooooo iiiiiiiiiit
Electrical tape, male and female connectors and a switch
1) Disconnect the battery
2) Unscrew the panel under the steering wheel to access the wires behind your headlight motor control button
locate the brown wire that connected to the switch and cut it
then tape up the two ends
3) Remove the fuse cover in the drivers side footwell and take out the 5amp fuse for your headlight motors (dont worry if everything is in jap its the only 5amp fuse in there)
4) Now this is what your going to be wireing up (the fuse in the diagram is the one you removed earlier)
should look like this
