Results 1 to 5 of 5
    Mar 2011
    Default greddy boost controller help please
    hi lads bought this off a buddie who bought the boost controller off here and i think it came off a s14 but i want to install it on my glanza anyone have any idea how to do this?or if i cant use it how much would i sell it on here for?cheers lads heres a pic and a link to youtube i found of it
    YouTube - ‪TRUST GREDDY profec B - Electronic boost controller Blue skeleton limited edition (GTR PCM VALVE)‬‏
    galway
    download the greddy instruction manual off thier website, i used to have the same boost controller and got it there.
    and you wont be selling that on here as you only have 10 posts
    Mar 2011
    sound man i tried but cant find it or make any sense of the thing!
    i no where the wires go its just the vacuums im stuck with im left with
    1, vacuum coming from controller says pressure in ?
    2, vacuum on solinoid going to the right ?
    3, vacuum from solinod with double end on it?
    any idea of how it was setup?
    i also forgot to add ill be using it for external wastegate setup
    May 2010
    The vacuum from the controller goes to boost source to take a reading so if you have a boost gauge in car you can T into that line.
    Has for solenoid one is in and one out, need to find out which.
    Out will go to actuator near turbo, should have STD solenoid plumbed in just remove this.
    In again is from a boost source so you need to tap into a boost pipe, closer to the turbo the better and try keep vacuum pipes short.
    Mar 2011
    thanks poc great help i have defo the one vacuum crossed off now which is the pressure in ill just join a t-piece to my boost gauge!
    as for the other 2 coming off the boost solinoid does it not need the t-piece?
    ill be running external wastegate td04 off of it its running .44 bar off the spring now and i have 2 ports on the wastegate one not being used now so im confused
