Results 1 to 10 of 21
    Jun 2011
    Default R32 running problems
    Hello lads
    When your driving along at a steady speed say 100 kmp the car will die in power , if you keep your accelerating it will flood itself but if you let off it wont cut out . So far ive changed fuel filter , plugs , fuel pump .
    I think its the afm what do you guys think. Should i change it ?
    Aug 2010
    Yeah its the afm definitely 100%
    http://tyresdublin.ie/
    Jun 2011
    Ive tryed cleaning it but it hasnt stopped so im thinking just to replace it
    Where is the best place to buy a afm if it close enough to sligo ill collect it 2moro
    Jun 2011
    cool drift the label is green
    Quote Originally Posted by jonny1505 View Post
    Well it's the right afm anyway.
    That part number or gap are the plugs ?
    Does it only happen when your driving at a steady speed or does it happen at certain revs ?
    Jun 2011
    Seems to happen at steady speeds mainly 80 - 100 kph nd 3,000 rpm
    the plugs seral number is Q20R-U11
    What mods does it have ,what colour is label on the afm ?
    What plugs did you put in ?
    Jun 2011
    Ok for some reason the car is boosting .9 bar but it s completly standard , the plugs are standard . the mods it has is front mount , hks air filter decat and exhaust system
