Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
  1. #11
    Cork
    Quote Originally Posted by jonny1505 View Post
    Seems to happen at steady speeds mainly 80 - 100 kph nd 3,000 rpm
    the plugs seral number is Q20R-U11
    I think the plugs are not suitable for 0.9bar boost.
    I'd recommend changing the plugs to NGK Iridium - BKR7EIX
  2. #12
    Jun 2011
    Them plugs where in it before hand and it still did it , i just changed them to see if it would help , i dont know whats happening , i went up to punchestown nd it did it loads of times really annoying
    Where can i get a secondhand afm in ireland ? and could i get there number
  3. #13
    Cork
    Well I'd still recommend BKR7EIX plugs ,might not solve the problem but at least they're the right plugs.
    There's several r32's being scrapped on donedeal.
  4. #14
    Site Trader: TDP - Trackday Performance
    If it's at part throttle cursing it's probally the O2 sensor. Try disconnecting it.
    Robbie
  5. #15
    Jun 2011
    Quote Originally Posted by robbie@tdp.ie View Post
    Robbie
    will do
  6. #16
    id try what robbies sayn first, knows his stuff.
    wouldnt go buyin an afm yet, just try borrow one of someone to see if it the source of the prob
    will ony take 10 mins to find out.
    only thing simular that happened to one of mine was cruising she wouldnt go past 6k, then 5
    then 4 then 3k got her to a mates house and she wouldnt start.
    went through all the usual shite, plugs, pump,afm,packs etc etc.
    turned out to be the cam gear sensor bearing had collapsed!
    hope ya get back goin again soon
  7. #17
    Jun 2011
    i unplugged the 02 sensor nd now it wont rev over 2,500 rpm
  8. #18
    what colour coilpacks are in them standard ?
    black man as standard
  9. #19
    Jun 2011
    there yellow ones in this
  10. #20
    Something wrong there it should run fine without the O2 sensor.
    Best thing is to get a some one with consult sw to plug in and check the sensors.
    Robbie
