will these drift buttons fit any car,or is there diff ones for each make of car??
Not sure, I'd say some cars would have slightly different sized buttons/holes so you'd wanna check really. You're basically just disconnecting the spring that pushes the normal button back out, and then the button attachment fits on so that you can pull the button back out manually when you need the handbrake to stay up
there's one size afaik, i had to pare down the stock button on my ones and push it down over
Few light taps of a rubber hammer did the jawb on mine
any1 else doing these buttons im after one at the minute
iv the driftworks one. myt not be the best of lookin but is perfect lad
Take out the spring, drill a hole offcentre on the button and stick a cable tie through it. Perfect job!
anyone else out there with one or know where to get one? other than the driftworks ones
got mine of driftworks also
