Results 1 to 9 of 9
Thread: Injector help
    Im not sure bout nissan injectors but it shouldnt matter what way the plug is,its simply being switched open and closed so it wont matter which polarity it enters the coil of the injector...open to correction tho...
    Quote Originally Posted by pt_y2k View Post
    What he said.
    You should be fine to connect it up as is. As long as it's getting a ground and 12v from the right sources it shouldn't make a difference
    i like stuff
    May 2010
    Quote Originally Posted by colm View Post
    What he said.
    I hoping thats the case! save more messing.
    Can anyone verify this?!
    Yeah doesnt matter what way the wires are on.. you might need to cut a little off the standard nissan plugs to make them fit on properly..
    May 2010
    Right have them in and car running but there is a loud ticking noise from the injectors now! Is this normal for some injectors?
    Car has not being setup for 550's yet I only tested it on idle to check if running
