Results 1 to 6 of 6
Thread: 1jz problem
    Default 1jz problem
    rite got the new soarer as a non runner found out that the igniter for the spark plugs had failed so that was fine she started up fine all be it spluttery so i changed the oil for 10 w 60 fully syntetic and a denso oil filter now it starts up fine but after about 80 - 90 sec it goes spluttery till it stall no matter if i rev or not dose anyone have an idea what it might be
    thanks
    Either not getting a Map signal Or dead Fuel pump...Sounds fuel related...
    10.5sec 1/4 mile @140mph Fastest s14 in Europe down 1/4 mile...
    fuel preassure reg gives bother on them, i had to replace one on mine
    Four doors 4 more whores
    Dublin
    Quote Originally Posted by yowdy View Post
    Quoted for truth, i needed to replace mine. they can be got from toyota
    "its cool i guess, but where are the other 2 doors?"
    Sedan Life since 2009
    FrSedan.com
    di Member 1jsoarer's Avatar
    yep the lads are prob right sounds like a fuel issue, the fuel pump ecu/reg (bolted under the back left window) gives bother sometimes too!!
    Signature removed
    grand i have the spare soarer there so il just rob it off that or head up to toyota thanks lads
