Results 1 to 4 of 4
    Feb 2009
    Default s14 temp gauge in cluster wont light up
    alright lads bit of a weird one,
    i have an import s14 (zenki) with white clocks & factory fitted h.u.d
    all the lights worked fine but the h.u.d tended to flickered no & again since i bought it, really bright to really dim etc.
    since then have done lots on the car including fitting a cilfford alarm, pfc & avcr
    anyway the temp gauge & half the rev counter doesnt light up anymore
    & i dont know if it happened after the alarm or other electronics were fitted as the car was off the road & its impossible to tell during the day as its quite a dim light from the clocks as standard.
    basically thought it was the bulb as you do so changed that & checked fueses
    & no issues as i could see, but still no light!
    it didnt really bother me but now it does
    on another note there was a boost gauge fitted which seemed to be wired off the dash loom & i moved this the other night (had to cut wires & rejoin
    to get it out) it worked fine after & of course went for a drive last night & the gauge is off (like getting no power) & the stalks for the indicators arent working the indicators but work for the headlights?
    the hazzard button still works the indicators though!
    now i havent checked fuses cos it was too dark last night but my question is
    would a blown fuse/bad wire cos the dash issue also?
    im guessing all the lights wouldnt work rather than just the temp side if this was the problem
    so any ideas???
    MEATH
    This the red s14 you had??
    its a faulty bulb holder, faulty bulb, or a damaged track on the circuit ont he back of the clocks, all the dash lights get power/earth from the same source, so its not the source if the rest are working.
    Jun 2011
    Quote Originally Posted by Dermot View Post
    spot on man got it sorted holder was bent alright! (this was for me not lukeworx finially set up me own account)
