Results 1 to 10 of 10
    Senior Member ste's Avatar
    north dublin
    Default s13 rear sub frame drop
    lads im in the middle of doing some dealings with a fellow member on some suspension parts... he's offered me a sub frame fitted with brand new dw bushes at a price i cant refuse so..
    as a mechanically retarded fuck, is it something i myself can remove or??
    Dec 2009
    Pure simple lad....! Disconnect the two shocks at the top then disconnet your brake lines and handbrake cable both sides.....! Put a jack under the diff and take out the 4 bolts holding the subframe in.....! Hole lot will drop straight down and everythings there in front of you....! If your not used to it take each arm off and put it on the other subframe....! Simples my mother could do it....!
    Bang it all back up....! Bobs your uncle fannys your aunt.....
    north dublin
    really that simple????
    the factory handbrake is gone already,stupid question but do i have to disconnect drive shaft and half shafts and drop diff casing etc
    i buying the sub frame with new dw bushes, cusco camber arms, new dw toe arms and new dw traction arms
    Dec 2009
    Just unbolt your diff and disconnect the drives at the hubs.....! Its a big bot a 32 or summit....! Its really simple lad when you get it out of the car you'l see everything in front of you....! Ya can't go wrong....!
    north dublin
    ya've never met me lol....
    sure ill give it a lash only way ill learn
    Jul 2010
    Meath
    Half shaft nut is a 36mm socket. It's real simple to do.
    di Member S13..KEV's Avatar
    Quote Originally Posted by pole drift View Post
    even pole drift ha ha ha
